vcMotionConfigurationMode
Module: vcRobotics
Parent: Enum
Referenced by: vcLinearMotionStatement.ConfigurationMode, vcMotionTarget.ConfigurationMode, vcRobotController.ConfigurationMode
How to access:
import vcRobotics as vc_robo
vc_robo.vcMotionConfigurationMode.<ENUM_VALUE> # replace <ENUM_VALUE> with the desired enum value
Enums
ValueDescription
FIXEDA robot's configuration does not change (no change).
FOLLOW_FRAME
A robot's configuration changes slightly to minimize joint value difference between its previous configuration (small change).
INTERPOLATE_JOINT_VALUES
A robot's configuration is determined by point to point interpolation of its joint values.
